86 tpi 305 starting issue
Old Dec 27, 2012 | 10:33 AM
timonator's Avatar
My sons 86 tpi 305 doesn't want to start when cold unless I hold the pedal at half throttle. Then when it starts it has to clear out like its flooded. Air pump and cat are gone. Tps is at.54v, initial timing is at 8, fuel pressure is 42 lbs with key on engine off.
What should I look at ?
Old Dec 27, 2012 | 11:51 AM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: 86 tpi 305 starting issue
You could try pulling the spark plugs to see if some are wet to identify leaking injectors.
Old Dec 28, 2012 | 06:23 PM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
Sounds like cold start valve is not working. May even be leaking causing rich condition, but my bet is on it not functioning at all.
I don't think they are available, so easiest fix is to use a block off kit ( ebay) and have the ECM re-programmed to an '89 program, which eliminated the cold start.
Fast355
Dec 2, 2016 06:33 PM
Wade787b
Sep 29, 2015 01:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 10, 2015 07:44 AM
86Base
Aug 8, 2015 01:34 PM
