build questions Block interchange head ?
Old Dec 28, 2012 | 07:12 PM
396lsx's Avatar
Car: 64'olds 442, 87 Formula 350
Engine: 350 tpi
Axle/Gears: 3.27 borg warner 9 bolt
I have a few questions as Im not familiar with the l98 platform so please excuse my ignorance.
My current tpi is sitting at 200k miles so I need to rebuild soon. I have a vortec block from a 97 pickup, would that work as a block so I can build it then just R&R when its done?
I have a set of World products SR torquers fully ported and ready to go, will these heads work with my factory intake (they have angled center intake bosses)
once again sorry for any repeat question and my ignorance.
Old Dec 29, 2012 | 02:13 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: build questions Block interchange head ?
Late model roller cam block ; best you can get used
Of more concern is if the ports ( how much ported ) match up to the stock TPI ports
You can slot the 4 center bolt holes just like the aftermarket TPI intakes to suit the pre '86 bolt style
Old Dec 29, 2012 | 08:07 AM
396lsx's Avatar
Engine: 350 tpi
the intake portions have not been ported yet, when It comes time they will be port matched.
Also my engine is a 87 so I believe it should have the angled center intake bolts right? that shoud mate up to the heads without slotting
Jake_92RS
Jan 28, 2020 10:37 PM
evilstuie
Feb 28, 2016 03:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
redmaroz
Aug 16, 2015 11:40 PM
BBSDesigns
Aug 11, 2015 07:39 PM
