Engine Running rich, Idle is low
Old Jan 27, 2013 | 11:23 AM
Josaiah89Iroc's Avatar
Car: 89 Iroc Z28 Camaro
Engine: 305 V8
I have an Iroc 89 Camaro with a 305 V8 TPI engine. It has rich exhaust and is giving me terrible gas mileage, like 10 to 13 mpg. I have replace the Ox sensor, throttle Position sensor, idle sensor, spark timing module, knock sensor, and the maf is only a year old. in the last week I have also changed the spark plugs, wires, and cap and since doing so the engine will want to die anytime I stop or coast through a turn, coming from a stop. If I keep my foot on the accelerator when I'm at a stop or coasting, the RPMs stay high enough to keep the engine running. I'm out of ideas on what to do. Also the spark plugs were black with soot. any ideas? could it be the fuel injectors?
Old Jan 27, 2013 | 11:42 AM
soarestransam's Avatar
Car: 1988 Gta trans am
Engine: LR4 4.8
Transmission: 98-02 t56 6 speed
Axle/Gears: Bw 9 bolt (3.70’s) pbr rotors
Re: Engine Running rich, Idle is low
possible injector staying stuck open
Old Jan 27, 2013 | 11:49 AM
Engine: 305 V8
what would cause that? age?
Old Jan 27, 2013 | 06:06 PM
southbay08's Avatar
debris that gets stuck in the tip of the injector partially occludes the flow causing the injector to leak. Run the engine then pull the plugs, if you have any wet cylinders then you have leaky injectors.
While you are at it you might want to check the resistance as well...both cold and warm. If any of them read 12ohm or below then your injectors need to be replaced.
www.southbayfuelinjectors.com
516-442-4707
Old Jan 27, 2013 | 09:09 PM
Engine: 305 V8
alright thanks for the tip!
Old Jan 28, 2013 | 10:04 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Possibly a bad CTS, you should also ohm your injectors like other user's have stated.
MustangBeater20
Oct 29, 2022 09:20 PM
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
squiggy2
Aug 9, 2015 09:30 PM
