350 build
Old Jan 30, 2013 | 11:20 PM
actarnoff's Avatar
Car: 1991 RS/B4C clone
Engine: 355 TPI
Transmission: Probuilt Street/Strip 700r4
Axle/Gears: 7.625 axle with 3.23 gears/TrueTrac
350 build
So we're currently building a forged 350 TPI. We haven't made a cam selection yet, but I'm trying to figure out what the difference is between these two cams?
http://www.summitracing.com/parts/cca-08-302-8
http://www.summitracing.com/parts/cc...04-8/overview/
The top end will be a ported Edelbrock base, with AS&M LTRs, a ported plenum, and a factory tb. We'll be using Dyno Don 1 3/4 headers and maintaining all smog equipment.
Thoughts?
Old Feb 6, 2013 | 04:35 PM
Tx 91Z28's Avatar
Car: 91/Z28/69SSCamaro/72Cheyenne
Engine: 350/350/350
Transmission: 700r4/400/350
Axle/Gears: 3.23/4.56/4.11
Re: 350 build
The main thing is the 2nd one is ground on a 114 center line with .500 lift while the 1st cam is ground on a 112 center line with less lift. To make the best choice you need to decide what gear ratio you are gonna be running,clutch or stall convertor? The center line will determine what rpm range the cam will work best at and at what RPM it starts kicking in. You can call Summit and get the tech line. They will walk you through the 2 cams. Just be prepared to answer questions about your total package. Hope this helps.
Jake_92RS
Jan 28, 2020 10:37 PM
Reborn756
Sep 4, 2015 03:42 AM
Eric-86sc
Aug 24, 2015 09:01 PM
NWAsonoma
Aug 18, 2015 05:45 PM
sreZ28
Aug 14, 2015 07:48 PM
