Dual PCV values...why didnt it work right?
Old Feb 9, 2013 | 06:12 PM
Guest
Guest
Posts: n/a
I did it...and...it worked "to well..."
Also the engine started running abit off. I pulled 1 of the pcvs off and their was the biggest SSSWWWOOOOSHHHH (vac suction noise) I pulled the dip stick out and their was air tryen to get IN their awell. Then the motor made a police siren noise, I yanked 1 back off and shut it down.
-Discuss
Old Feb 9, 2013 | 06:47 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Dual PCV values...why didnt it work right?
Because that's not how a PCV system works. Fresh air goes in one side, circulates through the crankcase picking up blowby gasses, and then gets sucked out through the PCV valve and burned off in the engine. With two PCV valves connected to vacuum, you're just putting the crankcase under vacuum all the time and not accomplishing much of anything.
Old Feb 9, 2013 | 06:49 PM
Guest
Guest
Posts: n/a
I just asked my buddy. Please delete thread.
-thanks
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
onefreakz
May 14, 2018 12:15 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
