How do TPIs start?
Old Feb 13, 2013 | 04:45 PM
MrPackstin's Avatar
Car: 1989 GTA
Engine: 5.7 w/Paxton
How do TPIs start?
I am trying to figure out how an excellent running TPI 305/350 is supposed to start. Do they "bump" start or do you have to crank them over a little before they actually start? Odd, question but I am having problems with mine in another thread.
Old Feb 13, 2013 | 05:01 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: How do TPIs start?
Originally Posted by MrPackstin
Do they "bump" start or do you have to crank them over a little before they actually start? .
Short version
The ECM runs the pump for 2 sec ( through pump relay ) when the key turned on to prime the rails , then turns it off
When cranking over ,when the ECM sees the dist ref pulses from the dist indicating the engine is turning over , it pulses the injectors
It also turns the pump relay back on
If the 2 sec prime pressurizes the system correctly ( and the pressure holds ) the engine should start with little / no cranking.
If needing longer cranking to start ,is a indication the pressure is not holding and you are relying on the OP switch to come online ( @ 4psi cranking oil pressure )
to run the pump directly and pressurize the system
Old Feb 13, 2013 | 11:51 PM
MrPackstin's Avatar
Car: 1989 GTA
Originally Posted by vetteoz
Short version
Thanks for a most thorough response! My '89 K1500 5.7 always required a little bit of cranking and my understanding is that is how they are with those low pressire TBI systems. My now newer '99 is just a bump of the switch.
Can you put the ESC into context for me?
Old Feb 16, 2013 | 01:12 PM
YenkoZ28's Avatar
Car: 1991 Z28
Engine: 305 TPI under 14 psi
Transmission: aftermarket T56
Axle/Gears: Moser 12 bolt 3.08 gears
Mine has always been a bump start.
Caspar
Jun 19, 2016 11:19 PM
Wade787b
Sep 29, 2015 01:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
L98GTA87
Aug 5, 2015 11:02 PM
