305 with 350 injectors?
Old Feb 28, 2013 | 02:22 PM
johnboy z's Avatar
Car: 1991 z28
Engine: 5.0
Transmission: 700r4 w/ shift kit
Axle/Gears: 3.23 limited slip posi.
I have a 305 but just picked up another hole tpi set up from a c4 corvette. Can I use the injectors on my 305? If so is their anything I have to change?
Old Feb 28, 2013 | 02:30 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: 305 with 350 injectors?
No, those injectors are going to be too big. Use the 305 injectors. 305 injectors are 19lb,while the 350 injectors are 22lb. Some of the Vette injectors are 24lb.
Old Feb 28, 2013 | 02:42 PM
Calixbwsx's Avatar
Car: 89 Iroc
Transmission: 700R
My car is a 305 but it has 22lb injectors should I change them to 19lb?
Old Feb 28, 2013 | 02:56 PM
johnboy z's Avatar
Car: 1991 z28
Engine: 5.0
I do have an upgraded intake, and ignition. Added air + added spark should = added gas.
Old Feb 28, 2013 | 03:19 PM
aldrichg9's Avatar
Car: 91 RS 5 speed
Of course you can use them. IF you tune for them.
Your PCM must know how the injectors act and if it doesn't then your fueling will not be right.
Posted from Thirdgen.org App for Android
Old Feb 28, 2013 | 03:23 PM
johnboy z's Avatar
Car: 1991 z28
Engine: 5.0
How could I get the pcm tuned for it? And would it be worth it?
Old Feb 28, 2013 | 03:32 PM
aldrichg9's Avatar
Car: 91 RS 5 speed
pcmsforless is one that's brought up on here often.
check with site sponsors to see if any will do it.
not worth it though for just an air intake. if you ported or changed heads, installed cam, port plenum, headers and exhaust.
or had a 350
Old Feb 28, 2013 | 03:33 PM
aldrichg9's Avatar
Car: 91 RS 5 speed
oops didn't finish my thougt... on the phone
...... then it would be worth it
Old Feb 28, 2013 | 03:55 PM
NCC-2569's Avatar
Car: 1990 Trans Am
Axle/Gears: Stock
http://tpiparts.net/
They have a programming service I used for my car.
You'll get a separate board onto which can you stick your actual PROM and it communicates certain values between ECM and PROM, e.g. your injector size.
I needed it because I swapped my dead 19lb for 21lb injectors.
Old Mar 4, 2013 | 04:27 PM
johnboy z's Avatar
Car: 1991 z28
Engine: 5.0
Thank for the info I checked out that site. I think I might go with adjustable fuel pressure regulator.
Old Mar 4, 2013 | 05:20 PM
ninetyone's Avatar
Axle/Gears: 3:42
That may not work out too good. You will have to turn the pressure down a lot to make your 22lb injectors squirt like 19's. It still won't run as good as if you had the proper size injectors in there.I would just change them to the proper injectors or you can get a custom chip made and get other stuff changed too in the process. Its up to you.
Old Mar 5, 2013 | 08:36 AM
johnboy z's Avatar
Car: 1991 z28
Engine: 5.0
Sorry mis understanding. Put the regulator in with my 305 injectors.
Old Mar 5, 2013 | 08:53 AM
ninetyone's Avatar
Axle/Gears: 3:42
ok, gotcha. Yeah that would be fine.
MustangBeater20
Oct 29, 2022 09:20 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
st.evel07
Aug 13, 2015 06:15 PM
