Tpi won't start wet spark plugs
Old Mar 11, 2013 | 03:42 PM
dez58pop's Avatar
Hi can you help I've got 305 tpi street & performance in 48 anglia I've had it up and running no probs first trn on key and now I'm getting a problem I'm cranking over and won't tart so try again then it gets slower cranking I'm getting 43psi up on psi gauge,when I take the plugs out there wet through,is this because its not cranking it over fast enough to start ,there recon injectors so I would have thought there shud be ok they've done no miles has its still a project,how long should it hold 43 psi for on the gauge with the key on could it be the fpr ?after about a minute it does slowly drop any help would be brill
Old Mar 12, 2013 | 08:55 PM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
Re: Tpi won't start wet spark plugs
Have you checked for spark yet?
Also sounds like your battery is getting a little weak.
1992 Trans Am
May 10, 2023 07:19 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
apo_bailon15
Mar 28, 2016 05:20 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
