tpi distributor?
Old Mar 24, 2013 | 11:52 PM
kill4thril's Avatar
Car: 1990 firbird formula
Engine: 355ci
Transmission: t56 spec3+ cluch
Axle/Gears: 9 bolt disc brake 2.77
tpi distributor?
ok so i am swaping my car from carb to tpi. and was just wondering about the distributor if i could use the msd street fire that i have or not i just put a 6al box in the car as well so the coil isnt in the cap anymore. but if i do have to get a new distibutor what would be a good one and would i still be able to use my 6al box?
Old Mar 25, 2013 | 12:16 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: tpi distributor?
No
You need a computer controlled dist that has provision for the 4 wires that connect to the computer
A MSD unit will work with one of those
Old Mar 25, 2013 | 11:24 AM
kill4thril's Avatar
Engine: 355ci
Ok thank you so I have a stock tbi distributor I would be able to use that right?
Old Mar 25, 2013 | 11:31 AM
hrspwr's Avatar
Car: 86 IROC
Engine: 350 Vortec TPI
Axle/Gears: BW 3.27
You can. Make sure the TPI harness is 88+ to utilize the remote coil. If the harness is an 86-87, you will either need a coil in cap HEI dizzy or convert the harness over to a remote coil(pretty easy).
Caspar
Jun 19, 2016 11:19 PM
stalkier
Dec 6, 2015 11:25 PM
86IROC112
Aug 17, 2015 02:00 PM
Out-Cast
Aug 17, 2015 10:57 AM
Sanjay
Aug 12, 2015 03:41 PM
