Got my scanner and decided to go for a drive. I don't really know how to read it, so maybe one of you fine people can help me out. It has some city and high way driving.
Things I want to know is:
How is it running over all?
how do you read this thing?
Which field is the Knock Count?
anything can be improved or "tweaked"?
Also, will this explain why I can mash the pedal all the way to the floor, get to about 120MPH without letting up and NEVER go above 3k RPM
Thanx in advance.
PS..Just an offer- anyone in the TUCSON area need a scanner or a borescope let me know.
Thanx in advance.
Let me guess win aldl ? Use tunerpro and repost.
tried tunerpro..couldnt get it to do anything. I dont have any bin or xdf files for it.
You only need the 32b ads.
ok????
Quote:
http://www.tunerpro.net/downloadBinDefs.htmOriginally Posted by Veaceonee
ok???? I know it is working becaue WinALDL is picking it up. But, in Tunerpro it doesnt recognize it. If the car is off its fine, turn car on it doesnt recognize the cable. Iv tried both the 6e and 120 bin and xdf files. Always says Hardware not found, DA Not connected. Please forgive my noobness.
Is this a USB cable, db9 serial ? Have you checked your baud on tp ?
Are you programing or emulating ? I'm not sure why you are using a xdf only 89 is 6e your 88 would be 32b.
