new to tpi injector size?
Old Apr 1, 2013 | 10:15 AM
kill4thril's Avatar
Car: 1990 firbird formula
Engine: 355ci
Transmission: t56 spec3+ cluch
Axle/Gears: 9 bolt disc brake 2.77
So I picked up a tpi intake for my 355 but am not sure what size injectors to use the engine has 10.3:1 compression promaxx 2121 heads and comp cam .503 intake and .510 exhaust any idea on what size to get
Thanks Jesse
Old Apr 3, 2013 | 07:21 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: new to tpi injector size?
If those heads are the 225cc intake version I'm thinking that cam (looks like a Comp 503; 224/230 ) is a little on the small size to match and the TPI is going to restrict them even more
Given the < 5000 rpm TPI intake limitations ,I suspect you won't be needing anything larger than stock 22 lb injectors ; 24lb at most
Old Apr 6, 2013 | 11:34 PM
Hello, Michael's Avatar
Car: 1987 Pontiac Firebird Trans Am WS6
Engine: SBC 350
Axle/Gears: 3.70:1 BW M78 9-Bolt Posi
I'm in the same boat. I'm rebuilding a 355, but I've got a Comp 306 cam with 510/540 lift and 229/245 duration with a 112 LSA. I'm trying to figure out if the 22# injectors will be ok, or if I should go with the 24#? I plan on using a set of stock L98 heads that have been ported and polished, along with larger dual springs and 2.020/1.600 valves. Can anyone recommend an injector?
toronto formula
Nov 10, 2015 06:17 AM
69 Six Pack
Oct 5, 2015 07:51 PM
wruiz
Aug 13, 2015 09:07 PM
Sanjay
Aug 12, 2015 03:41 PM
knight72
Aug 10, 2015 09:32 PM
