89 egr solenoid valve, 305, need help please
I am reworking a tune port set up that has no vacuum lines and I saw somewhere on the third gen site that a vs25 solenoid would work, so I purchased one. Now I'm having trouble figuring out what needs to go where. This solenoid valve has two plastic ports on one end and a bright metal one on the opposite. One of the plastic ports has what appears to be a reducer inside. Can someone walk me through this?
Thanks in advance.
Thanks in advance.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 89 egr solenoid valve, 305, need help please
If you need a oem one I can sell you one, hopefully you have the right connector. The ground and hot side of the solonoid does not matter. You have a vent port usually with a foam filter and 2 nipples. The solonoid gets ported vacuum from under the throttle body the other port of the solonoid goes to the egr valve. This is a normally open solonoid .
Thanks for the response. That explains the foam over one of the ports. I have attached a couple of pix of the plug and if yours will mate to it, how much?
Engine: Lb9
Transmission: M20
It depends on where you are located at, the solenoids were the same for camaro and firebird 87-92. I would do 25 shipped .
Engine: Lb9
Transmission: M20
I will pm you tomorrow some time with the tracking number.
You can try to contact @Tuned Performance who is a board sponsor, and may be able to advise you better about availability. You could also retrofit a later solenoid valve, such as the AC-Delco 214-2207, but that would require changing the electrical connector on the engine wire harness as well.
Engine: Lb9
Transmission: M20
After 10 years it’s gone, you might retrofit one or post in classifieds wanted section.
