Fuel hoses, Filter, What to change?
Old Apr 29, 2013 | 07:53 PM
86WS6's Avatar
From: Great Smoky Mountains, Bryson City North Carolina
Car: 86WS6 30K and 82WS7 24K
Engine: 86:305 TPI, 82: 305 LG4
Transmission: 86:700R4, 82: T200C
Axle/Gears: 86:3:27 9 bolt, 82: 3:23 10 bolt
My car is an 86 Trans AM with the 305 TPI. This is one of those cars that sits most of time, gets started once a week, driven around the neighborhood until the operating temp is normal, then put back into the garage. It is all stock and has 29K miles on the odometer. We have been careful to run premium ethanol free fuel in the car. The car is currently running well, and has no codes set. The original rubber fuel hoses and filter are still on the car. I figure that I have borrowed enough time, and need to change them before one breaks and sets a fire. I have a few questions, and appreciate anyone who takes the time to answer.
1) Can all of the hoses be changed without dropping the fuel tank?
2) is the filter located on the undercarriage? Is there a secondary filter anywhere on the car? I am assuming that the screen on the fuel pump intake inside of the fuel tank has no specific life span, so it should only be changed with a fuel pump failure?
3) Are there rubber hoses on or around the engine that should be changed? Any "o " rings that should be changed as part of routine maintenance?
4) Is standard fuel injection hose from NAPA safe, or should I invest in something better?
Thanks in advance.
Charles
Old Apr 30, 2013 | 12:48 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: Fuel hoses, Filter, What to change?
Great looking car!
The fuel filter is under the car, infront of the rear axle on the drivers side.
I would not worry about replacing any soft lines or o rings, unless you suspect a leak.
Old May 1, 2013 | 01:15 AM
86WS6's Avatar
Originally Posted by Johnny Blaze
Great looking car!
Hey Johnny, Thanks for the compliments and the info.
The car is a decent number 2. It looks great from 10 feet. Up close, it has some patina, but is a very solid mostly original car.
I will get her up on jack stands and tackle that fuel filter. The rubber hoses that one can see from looking under the car have fine cracks in the surface. It is probably cheap insurance to go ahead and change them out, rather than wait for a failure.
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
Logan Bryant
Aug 27, 2015 11:52 AM
kyleb24
Aug 15, 2015 08:24 AM
