Bosch type 3 yellow injectors.
Old Apr 29, 2013 | 10:03 PM
MrWillys's Avatar
Recently,
Old Apr 30, 2013 | 02:56 AM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Re: Bosch type 3 yellow injectors.
I purchased a set of Bosch 3 fuel injectors from Souhbay. After installing them I noticed my BLM was 160 instead of the ideal 128. Not sure what that means. I was concerned that it would not pass the emission test. I recently took the car for inspection and it passed the emission test. Car runs great with the Bosch 3's. Maybe your having other issues. Have you tigthened the runners bolts. After severl weeks of cruising, I found found several runner bolts loose. Have you checked your EGR. If the EGR is stuck open at idle, the car will run rough. Wish you luck.
Old May 1, 2013 | 07:41 PM
MrWillys's Avatar
Fred, blm counts of 160 means the ecm is adding as much fuel as it can. Keep an eye on these, and consider turning up fuel pressure a lb or 2, or more depend on on blm. Work toward 128.
Old May 4, 2013 | 12:15 AM
Fred SS's Avatar
Transmission: 2004r
I had a Holley AFPR and it leaked thru the diaphram. Which brand would you suggest?
Linson
Oct 24, 2025 02:00 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Rocket-Doc
Nov 14, 2015 02:08 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
