TPI roller cam, is ok to run a carb on?
Old May 6, 2013 | 12:49 AM
Z28NZ's Avatar
Car: 85 Z28
Engine: 355 Vortec TPI
Axle/Gears: Stock
Hi all, am presently building my first roller cam engine (retro fitted to flat tappit block) and am not 100% sure what the end usage will be for yet, ie, 3rd gen or 60's Impala.I want to keep my options open so I was thinking of fitting a comp cams XR276 HR tpi cam in case I go tpi with it as I have a XE268H-14 in my 85tpi camaro and love the way it performs. Question is-
If I choose to carb this engine, would it run and perform ok with a computer cam in it? Someone must have done this and knows how it would go-
Cheers
Old May 6, 2013 | 07:10 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: TPI roller cam, is ok to run a carb on?
It will run fine. Carbs usually benefit from tighter lsa cams but will run a wider lobe separation
Old May 8, 2013 | 04:20 AM
Z28NZ's Avatar
Car: 85 Z28
Axle/Gears: Stock
Thanks for that Orr, a tpi cam it is then!
midge54
Dec 27, 2019 04:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
camaro71633
Sep 1, 2015 10:24 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
anesthes
Aug 8, 2015 09:37 PM
