Fuel return line question
Car: 1987 Iroc-z
Engine: 355/Edelbrkhds/lpe219cam/MiniRam/
Transmission: 700R4/3.27 9bolt
guys, I have an 87 IROC 350, which fuel line is the return? Hooking up a Miniram... Thanks.
Car: 1987 Iroc-z
Re: Fuel return line question
forgot to mention I need to know the return line on the miniram and in the engine bay.
Engine: 4++,350 & 305 CIs
On the car or on the MR ?
Car: 1987 Iroc-z
Both, trying to hook up the custom braided lines I got with the Miniram to the car.
Car: 1987 Iroc-z
Thanks for the info, I'm amazed that you would know that the 14mm line is the return line off the top of your head. I hope some Miniram guys will chime in on the answer about the return line on the back of that.
On the MR, its the one going to the fuel rails and filling the injs. If its a newer on the regulator is on the dr side rail and the line coming off the bottom(?) of the regulator is the return.
Car: 1987 Iroc-z
Ya its brand new, so the driver side/regulater side line is the return line? One more question, Tuned Perf said the 14mm line is the return line, I'm at work so I can't get to the car. Are the nuts really different sizes? I thought they were the same.
You'll have adapters for your stock fuel lines. Your stock lines are diff sizes but MRs are the same size.
Car: 1987 Iroc-z
Thanks guys, I'm at work with my shop manual that's as big as a phone book so you guys just saved me a lot of time digging through it...
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The feed on the mini ram would got to the rails and the return is the line off the regulator.
Engine: Lb9
Transmission: M20
Car: 1987 Iroc-z
Cool, so the smaller line is the return line in the car, now I get it. I knew I was missing something. And please don't send me a bill, the new Miniram cost a fortune.
