Top End Rebuild
Old May 8, 2013 | 04:00 PM
Termanalor117's Avatar
Car: 1991 Pontiac Firebird Trans Am
Engine: 1987 Chevy 355 TPI Mild Cam
Transmission: 5-Speed T-5 WC
Top End Rebuild
Just need some simple questions answered. Thanks!
This picture, the sensor circled in red, what is it?
These two sensors go on the side of my heads, I think....
If you could confrim that is where they go and what they are. I think they are the coolent temp sensor and fan switch but not sure and not sure which one goes on which head.
I found this hidden in the back of my engine bay, the previous owner blocked it off for some reason, if you know what it is and where it goes that would be helpful. It appears to be some sort of hose line, it goes into the line that goes off the side of the picture.
Thanks for all the help!
Old May 8, 2013 | 08:01 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Re: Top End Rebuild
First pic is a coolant temp sensor. Second pic is a vacuum line for the accessories like the air vents inside the car. It t's off to the plenum and the ball under the left fender.
Old May 9, 2013 | 06:34 AM
Re: Top End Rebuild
Ok great thanks, no idea about those two sensors in the second pic?
hectre13
Dec 11, 2023 08:14 AM
SiCkRs
Members Camaros
32
Jul 1, 2018 04:53 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
sreZ28
Aug 14, 2015 07:48 PM
