Head question
Old May 18, 2013 | 11:04 AM
Termanalor117's Avatar
Car: 1991 Pontiac Firebird Trans Am
Engine: 1987 Chevy 355 TPI Mild Cam
Transmission: 5-Speed T-5 WC
Head question
The hole that is in the center, not the spark plug or exhaust obviously, is that for the fan switch/coolest temp sensor or what? Thanks
Old May 18, 2013 | 08:50 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Head question
Depends on the side of the engine
One head has the temp gauge sender , the other has the fan switch
Check out what ( a single wire ) engine wiring nearby you have that is not connected to anything;
the connector on the end of the wire will tell you what unit ( sender or switch ) you are missing
The coolest temp sensor ( CTS ) for the computer is always at front of the intake ; not in the head
Old May 19, 2013 | 08:55 AM
Re: Head question
Ok perfect, thank you!
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
