1988 tpi fuel pressure specs
Car: 1988 iroc-z
Engine: 5.7 tpi
Transmission: 700 r4
what is the fuel pressure spec for a 1988 5.7 tpi engine.my is 43 psi with ignition on and when cranked it idles at 35 psi.
Transmission: T-5, TH350, T-5
Re: 1988 tpi fuel pressure specs
Thats the way it should be. You're in spec.
Car: 1988 IROC-Z Convertable
Engine: 350 Cam, Heads, Heders...etc.
Transmission: 700-r4 "Raptor"
You didn't mention how you measured it so to be sure, you need to disconnect the vacuum line to the fuel pressure regulator when measuring it; 43.5 is what it should be at idle.
Car: 89 iroc z
Engine: 353tpi
Axle/Gears: 342
It should idle at 43 and your is at 35 idle I'd get another pressure gauge and if it stills. Shows 35 check your fuel filter
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
vacuum line disconnected and plugged, and the other side of the vacuum line at the plenum should be capped off too. Car idling in park and the pressure should measure 43.5 psi (stock).
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
