bog down or hesitation on accelleration
Old Dec 4, 2008 | 11:32 PM
cs11091's Avatar
Car: 85 tpi iroc z
Engine: 305 tpi
Axle/Gears: 4:10
ok this has me completely baffled, i have been on this project for 8 months and i will try to be as specific as possible,i have a 85 305 tpi with a cold start injector , before i rebuilt the entire engine of the car i had a pre existing bog down, or hesitation problem, kinda as if the car isnt getting enough air , fuel, or restricted exhaust flow, i noticed the car would increase in rpm as i drove it and pressed the gas slowly and steadly, but if i floored it it was allmost like there was a rpm govenor. but if i was in park it would redline fine and then somtimes in park it would bog down, first thing i was told was a maf sensor, so i checked it and it had a ripped screen so i bought a new one $300, didnt fix the problem, next checked my distributor and rotor and cap and plugs and wires and correctly zeroed out the timing they all got replaced $500. then i started having idleing problems and black smoke, so at 160000 miles i said screw it i will just rebuild the engine, $3000 dollars everything got redone or replaced except for the crank, including all sensors except for the iac. new knock sensor $50 coolent sensors tps $60,cold start $100 etc... got the engine in and same exact bogging problem so replaced the injectors $550, replaced intake $150, replace water pump, radiator, goodyear hoses, $400 had the throttle body rebuilt $200, borla exhaust $1000, you get the picture come to find out i suddenly kept blowing fuel pump fuses, come to find out ecm was shorted somhow and blew a capacitor clean through the board, new ecm $110, also rechecked the entire wire harness wire by wire no shorts or bad relays, check and replaced all vaccume hoses and have check with smoke machine, i removed the catalitic converter thinking of exhaust restriction with no luck, ive cheked proper voltage on tps and reset iac several times. now she idles 1800 rpm and is barly able to accelerate. now heres the kicker when she shifts into 2nd 3rd gear when she is boging as soon as the shift happens it stops bogging down, and at high speed no bogging at all when i accelerate she will downshift and acclerate great, i have even tried adjusting my kickdown cable.
http://www.cardomain.com/ride/3108265
BTW: the comp is throwing no codes and no lights!!!!
please help <<< yes i know i am an idiot for ivesting this much money and i am running out of ideas
Old Dec 7, 2008 | 08:57 PM
85gulstrandTA's Avatar
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
Re: bog down or hesitation on accelleration
Man Somebody help him.
Can the ignition module controll the fuel in a tpi ?
I know it does on my tbi 454 truck.
Old Dec 7, 2008 | 09:10 PM
Gary Berg's Avatar
Car: 86 T/A WS6/Future project
Engine: 350 TPI/ Pontiac 455
Transmission: 700R4/TH400
Axle/Gears: Posi.
Your not the only one my 91 t/a is doing the same thing!!! I have a cold air intake on it and a new fuel pump that pumps plenty of fuel!
Old Dec 8, 2008 | 12:10 PM
Gary Berg's Avatar
Axle/Gears: Posi.
if anyone can help me out with this problem please leave ur insight.
Old Dec 8, 2008 | 06:09 PM
Gary Berg's Avatar
Axle/Gears: Posi.
it also afects my gas mileage because i have to give it more gas.
Old Dec 9, 2008 | 05:35 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
A bog is usually caused by incorrect spark or fuel related.
What's your fuel pressure and how long does it hold?
Old Dec 9, 2008 | 01:02 PM
Gary Berg's Avatar
Axle/Gears: Posi.
how do i check fuel pressure? i dont have a guage. and i do have cheap ac delco plugs.
Old Dec 9, 2008 | 08:55 PM
86camaroZ's Avatar
Car: 86 iroc
Engine: 350 vortec HSR
Axle/Gears: 370
change your fuel filter lately?
Old Dec 10, 2008 | 12:01 AM
AaronIROCZ's Avatar
Moderator/TGO Supporter
did you replace the coil??? Does the car idle good??? Sounds like a problem i had with a s-10 jimmy I had, it would idle fine but once you gave it gas to accelerate it would spit and sputter, I could barely do 45 on the interstate!!! I replaced the coil and it ran good ever since. The coil got weak and once cylinder pressure increased it made it harder and harder for the weak spark to jump the gap on the plugs.
Old Dec 10, 2008 | 12:22 AM
GOATS2QUICK's Avatar
Car: 89 trans am / 67 gto
Engine: 350TPI
Transmission: AUTO
Axle/Gears: 3.27 9 bolt
yes, my 88gta was runnin like that, cooil would fire the car, but just barely, i swapped it out and boom, instant power!
Old Dec 11, 2008 | 12:27 PM
Gary Berg's Avatar
Axle/Gears: Posi.
ya it idles fine. and i recently changed my fuel filter.
Old Jan 30, 2013 | 06:00 PM
nuggie's Avatar
Car: 91 Firebird, 87 E'LS' Camino
Engine: 5.7 TPI, 5.3
Transmission: 700R4,200R4
Axle/Gears: 4.10 Lock Right locker/2.43
I have a similure issue on my 91 T/A 5.7 too me though it seemed more like the trans was the problem I recently had that rebuild by professionals so havn't dug any deeper into beyond theory. I could try the coil though my could have gone bad because my plug wires were bad and it was sparking through the wires to the coil case. did you guys experience surging at stop lights?
Old Jan 30, 2013 | 06:21 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Before you go buy a coil, test it.
https://www.thirdgen.org/forums/elec...-tpi-coil.html
Old Jun 6, 2013 | 09:44 AM
smittyakalance's Avatar
Car: 1991 Z28
Engine: 383 Stroker with edelbrock heads
Axle/Gears: 4.10 Posi
I'm sorry to be the one that is telling you this, but sounds like you blew a lot of money already...... you need to refind top dead center.... and line up the 0 on your harmonic balancer to the timing tab. After you do this you need to hook up a timing light and advance or retard the timing until you have it running without sputtering and bogging down cause mine was doing the same thing until i fixed the timing and have had no problems since...
Old Jun 6, 2013 | 10:06 AM
carattini's Avatar
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
Grant2k
Apr 4, 2016 08:21 AM
85 Jimmy
Sep 30, 2015 07:56 AM
RedLeader289
Sep 23, 2015 06:50 AM
