Quest to run a 8.5 with my tpi
Old May 11, 2013 | 09:03 AM
dusty's89's Avatar
Car: 89 iroc z
Engine: 353tpi
Transmission: 700 r4
Axle/Gears: 342
I'm running 1/8 mile here's my time slip reaction .589 60 ft 2.027 330 ft 5.835 594 ft 8.467 1/8 9.055
Old May 11, 2013 | 02:05 PM
dusty's89's Avatar
Car: 89 iroc z
Engine: 353tpi
Axle/Gears: 342
Re: Quest to run a 8.5 with my tpi
Any ideas
Old May 12, 2013 | 08:32 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Post complete specs of current setup.
Old May 22, 2013 | 01:25 PM
89gta383's Avatar
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
The 9.05 1/8 mile et equals about a 14.20 1/4 and an 8.5 equals about an 13.34 in the 1/4. A torque converter and sticky tires along with basic mods (free mods, exhaust, pullies) should get you there.
Old May 25, 2013 | 10:50 AM
dusty's89's Avatar
Car: 89 iroc z
Engine: 353tpi
Axle/Gears: 342
I ordered a custom chip for it
Old May 25, 2013 | 12:11 PM
Car: 1971 Camaro
Engine: 427
So what's your current set up?
Who is burning the chip?
Old May 25, 2013 | 04:52 PM
dusty's89's Avatar
Car: 89 iroc z
Engine: 353tpi
Axle/Gears: 342
Hooker headers msd6al air foil k n filters 342 gears
Old May 25, 2013 | 05:35 PM
Car: 1971 Camaro
Engine: 427
Stock longblock?
L98?
Is it bored like .020" or something?
Everything else stock?
Old May 25, 2013 | 06:06 PM
dusty's89's Avatar
Car: 89 iroc z
Engine: 353tpi
Axle/Gears: 342
Ya its bored 20 over every thing else is stock
Old May 25, 2013 | 06:31 PM
Car: 1971 Camaro
Engine: 427
Tires?
Rear suspension?
Old May 25, 2013 | 06:46 PM
dusty's89's Avatar
Car: 89 iroc z
Engine: 353tpi
Axle/Gears: 342
235/55/16 Yokohama I've got relocation brackets Polly urithan bushings
Old May 25, 2013 | 07:00 PM
Car: 1971 Camaro
Engine: 427
Get some slicks or drag radials.
Get that 60ft tine down.
Old Jun 2, 2013 | 10:52 AM
dusty's89's Avatar
Car: 89 iroc z
Engine: 353tpi
Axle/Gears: 342
K ill do that thanks got another question what's the biggest cam I can put in with out putting a stall in
Old Jun 6, 2013 | 10:08 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
without changing the stall there's not to many options out there. if you've got the l98 cam you would be better of putting a set of 1.6 rockers on than tearing into the engine.
Old Jun 7, 2013 | 09:09 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Unless you had it tuned local, send that back.
Do a performance trans rebuild with good converter and use drag radials or slicks.
Old Jun 7, 2013 | 09:21 AM
Car: 1971 Camaro
Engine: 427
Wrong question.
You should ask, "Whats the best cam for my set up and goals?"
Fill out a cam request form on your choice of brands website.
Need a lot of details to pick a good cam.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Sanjay
Aug 12, 2015 03:41 PM
Bradsaundry
Aug 12, 2015 12:34 AM
squiggy2
Aug 9, 2015 09:30 PM
