deleting cold start injector on a 1988 5.7 tpi
Old Jun 7, 2013 | 05:42 AM
88zroc's Avatar
Car: 1988 iroc-z
Engine: 5.7 tpi
Transmission: 700 r4
rather than replacing a bad 9th injector,what is best procedure to delete it? can I just unplug it and run a 1989 prom chip or reprogram mine?
Old Jun 7, 2013 | 05:55 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: deleting cold start injector on a 1988 5.7 tpi
Correct ( so long as it is electrically bad and not leaking fuel.)
Disconnect the connector from the CSI switch ( the brass hex head unit shown below ) at the front of the intake and it will never run again
If the CSI is leaking fuel then you need to remove and plug the line to it from the end of the rail
Old Jun 7, 2013 | 12:22 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
If you are wanting to go with the $6E 89 Programing send me a pm I can assist you with the change.
http://www.ebay.com/itm/Chevy-TPI-SBC-Cold-Start-9th-Injector-Block-Off-Delete-Kit-/380643829414?pt=Motors_Car_Truck_Parts_Accessories&hash=item58a023e6a6&vxp=mtr
Old Mar 18, 2014 | 09:19 PM
Mtwise's Avatar
Car: 88 IROC
Transmission: 5 Speed
I have an 88 305 and the CSI senor/switch in the front of the block, is not there. Plugged/removed/or engine swap from previous owner I have no idea.
My question is with nothing plugged in would I still need to disconnect the wires to the 9th injector, or since there is no temp signal will it never fire?
Matt
Old Mar 19, 2014 | 01:55 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
No
Old Mar 19, 2014 | 08:09 PM
Mtwise's Avatar
Car: 88 IROC
thnx
Old Apr 2, 2014 | 04:15 PM
alex722607's Avatar
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
What would happen if you run a 1989 350 memcal with a 1988 350 engine and NOT delete the cold start injector. I am asking because I did this and my car kept stalling.
Frozer!!!
Jan 19, 2024 04:55 PM
jklein337
Sep 19, 2018 06:23 PM
italiano67
Dec 11, 2016 09:21 AM
Wade787b
Sep 29, 2015 01:15 PM
drathaar907
Aug 6, 2015 04:20 PM
