TPI Runners
TPI Runners
Ok guys heres my question can you flip the runners on a tpi? The reason i ask is that i bought a 70 chevelle with a tpi injection system on it.It has a vacuum leak on the pass side.I removed the runner and replaced the gasket but it still leaks.The runner has a port on it that has been plugged.It looks like the port for cold start injector.I thought that was only on the drivers side.The runner looks like it is not sitting correctly on the intake.It is leaking right in that area.Its not the plug but where it mates to the intake.Thanks for any help.
Re: TPI Runners
I thought maybe i could just swap them back.Assuming they where installed wrong.So do you think that my right side runner is originally a left side runner w/cold start valve?
Car: 1989 Firebird Formula
Engine: 305 tpi
Axle/Gears: 3.73 posi 10 bolt
Re: TPI Runners
The cold start injector is supposed to be on the drivers side but I jus swapped runners on my firebird and I am having the same issue except my runners have the cold start injector on the drivers side my car is an 89 with no cold start injector
Engine: 4++,350 & 305 CIs
Re: TPI Runners
Along the top front of the "pass runner only", the runner and the gasket, have a slight angle to it that matches the plenums downward slope.
It sounds like yours are most likely swapped side to side.
Sanjay
Aug 12, 2015 03:41 PM
