Edelbrock TPI Intake
Car: 1989 Iroc Z 5.7L
Engine: 5.7L
Axle/Gears: built 4.10s
Guys, I am getting ready to re-install my TPI intake and am wondering if I need to check and/or clean the 5 bottom side clean-outs? I assume they are clean outs, am I correct?
Another question, what it the rear threaded port in the rear of the intake by the distributor for?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Edelbrock TPI Intake
That hole is 1/8 npt and can be blocked . Corvettes had a steam hole fitting there. You will want to notch your remote coil mounting bracket so it sits flush.
Engine: 5.7L
Thanks! I will go look at that it. Really like how you modified the bracket because my car had those stock bolt studs and they were loose when I was trying it apart to fix coolant leaks.
The reason I asked about the bolt is a previous owner of this car hacked up (cut) a 3/8" bolt and wrapped it with teflon tape and it looks to be another area that was leaking.
Engine: Lb9
Transmission: M20
Since the po jacked up the air bleed hole, there is another passage on the drivers side were they drilled the passage for the pcv passage that should be blocked with a 1/8 npt as well.
Engine: 5.7L
Yes, the driver side is plugged but the passenger side is messed up and leaking. I guess I will have to probably drill and tap it for a larger bolt. Maybe I will have to call Edelbrock tomorrow and ask them.
Engine: Lb9
Transmission: M20
You could drill and re tap to 1/4 npt are since some one jacked the threads you could try using a thread chaser and reinstall with a flanged washer and crush ring under the head of the bolt with teflon sealer on the threads.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Engine: 5.7L
I called and spoke with Edelbrock before doing anything. I explained how someone before me threaded a standard 3/8" UNC bolt all the way down into the coolant port. He told me to be careful because there is not a lot of material in that area and there is a chance that tapping it could crack the aluminum, so I asked what about welding it? He said since I did not need that port that welding would probably be the best option. So I found a guy local here to weld up that hole. I hope it holds!!!
Also took the recommendation to modify my coil bracket to work with the intake and ARP bolts
1992rs/ss
Jan 31, 2025 05:10 PM
86IROC112
Aug 17, 2015 02:00 PM
Sanjay
Aug 12, 2015 03:41 PM
