Cheap/ good aluminum heads? Possible to get both?
Car: 1985 Volvo turbodiesel
Engine: 1989 305 TPI in the Volvo
Transmission: 1990 700r4
Axle/Gears: 3.73 Dana 30
What are the best bang for the buck aluminum heads? Will be going on an 89 305 TPI motor. Not concerned about major HP gains, more with efficiency and able to bolt on my stock intake, accessories etc.
Are the sub 800.00 complete heads garbage or just prices dropping?
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: Cheap/ good aluminum heads? Possible to get both?
The cheapo ebay stuff/overseas wouldnt touch em
Maybe some used 113s?
Dart SHP isnt bad for the buck, Edelbrock isnt a bad entry level alum head havent kept up on Trick Flows stuff.
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
I know the later year Corvette 113's were good (with the D shaped exhaust ports.)
Car: 87 Iroc
Engine: modified 350
Transmission: high performance built 700R4
Axle/Gears: Strange S60 3:73
I've heard good things about Flo Tech heads.
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Keep in mind that with the exception of Trick Flows, I'm not sure of any aftermarket aluminum heads that offer a small enough combustion chamber to keep your compression ratio where it is now. The 113s or the Trick Flows would be my choice in order to keep your compression up. Additionally, the small-ish ports of the 113s and those Trick Flows should keep low speed velocity up which will help keep your 305 from getting soggy at low rpm. Most heads designed for larger cubic inch motors aren't going to help a 305 build good torque at low rpm.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
You cant put most 2.02 or larger intake valve heads on a 305! It will hit the cyl wall if valve lift is over .430", which stock lb9 cam could be .415 with 1.5 rockers. it would be severely shrouded and may hurt flow and not give you gains. If you want aluminum, tfs small bore heads would work with a 1.94" valve. Else go 113's rebuilt
Thanks, I don't want to lose compression and am not concerned with squeezing biggest possible valves in there, just a slight upgrade and a few lb's lighter. I've got a set of 1.52 roller tip rockers waiting to go in, not worried about the cam, call me crazy, but I like the torque curve of the stock cam. I'm probably just gonna get some refinished iron heads and call it a day, but aluminum is soo pretty and I like adding lightness
Trying to remember, stock 305 TPI heads are 56-58 cc? stock valves are 1.8xx/1.5xx?
ugh, doing a bit more searching and it's hard to find aluminum heads with out 2.02 valves. The search goes on
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Or if you can wing it go for a set of modified early model LT1 heads, From what I read from one of the articles posted here from a company that was offering them that they were a 35 hp increase over stock ZZ4/113 heads. If you can get a set on the dirt cheap and have them modded that could be a good way to go.
Car: 1989 Iroc convertible
Axle/Gears: 3.08 posi
Axle/Gears: 4.11
They are full of something just not the truth Joined: Apr 2004
Maybe but like I said if he could find a set on the dirt cheap ( I've bought multiple sets of LT1 heads for 50-100 bucks) Pay somebody to mod them or if he can weld them up himself then he'd be miles ahead of trying to get a set of ZZ4 heads (even used they usually run about 500-700 bucks).
Here's the thread with the article included...
https://www.thirdgen.org/forums/fabr...n-project.html
91 rally sport
22
Apr 5, 2016 05:06 PM
Navy8125
Aug 22, 2015 07:13 PM
