Hard to start
Old Jul 14, 2013 | 04:16 AM
Gregdonna's Avatar
Hard to start
i have a 92 Z28 and it is hard to start i just tuned it up with new plugs cap rotor wires. and still hard to start. Will a injector that has a bad seal cause this problem is there a way to check if this is the problem. Or is one or more of the coils low and need to be replaced HELP.
Old Jul 14, 2013 | 11:06 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Hard to start
What do you mean by hard to start? It cranks a long time before firing? Cranks slow? Sputters while cranking but doesn't stay running all the time? An injector seal will likely cause a fuel leak, possibly a vacuum leak. Either way fix it. Then you can rule it out. What coil are you referring to and what do you mean by 'low'? There should only be one ignition coil unless you converted to a LS1 ecm.
Old Jul 14, 2013 | 04:12 PM
Gregdonna's Avatar
Re: Hard to start
it cranks over a long time and them it will fire and runs good just takes a long time to fire. And im wrong about the coils i have just the stock coil on my car.
Old Jul 14, 2013 | 05:27 PM
Re: Hard to start
How long does it crank? My initial guess is the fuel at the fuel rail is bleeding back in to the tank. Hook up a fuel pressure gauge and turn on the key. Doesn't need to be running. Your static pressure should be close to 43psi. Then turn the key off and see how long it takes for the pressure to drop off. It should hold most/some of the pressure for at least a half hour. If it doesn't then either you have a fuel pump that's letting fuel back or more likely a pulsator (its between the fuel pump and the sending unit, fuel passes through it) that is leaking fuel out. Either way the gas tank would have to come out. https://pontiworld.com.au/usgmsp/pro...oducts_id/5310
Old Jul 15, 2013 | 01:54 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Hard to start
Originally Posted by Gregdonna
it cranks over a long time .
Can you hear the pump run for 2 sec when you 1st turn the key on?
If not , you are not getting rail prime; key on and have to wait until the OP switch runs the fuel pump
Old Jul 15, 2013 | 02:49 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Hard to start
When I start getting longer than "normal" crank times, I've found that replacing the fuel filter fixes it. I don't know why but it just does.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
