Car never starts initially
Old Jul 28, 2013 | 09:55 PM
BftCamaro's Avatar
Car: 1987 camaro Z28
Engine: 5.0 TPI LB9
Transmission: 700r4 auto
Axle/Gears: 2.62:1
Like the title says ...I would turn the key and it cranks but won't run...now it does this new thing when I turn the key it cranks and runs for like 1 second and turns off but if I crank it and when I starts I give it some which is a understatement of gas and it runs .... I think it's the cold start valve cause once it sits this is when I have this problem ...but if I cut it off after it runs it starts right back up ...what you guys think?
Old Jul 29, 2013 | 07:54 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Car never starts initially
https://www.thirdgen.org/forums/tech...formation.html
Old Oct 19, 2013 | 09:39 PM
321FormulaGuy's Avatar
Car: 1990 Pontiac Firebird Formula
Engine: 89 Camaron IROC-Z 350
I'm having a similar issue, did you ever figure out what was wrong?
Old Oct 19, 2013 | 11:43 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
FWIW
If you have to give a EFI engine " gas" for it to run then it is way rich because giving it "gas" means you are putting more air to lean things out
It does not give more fuel like pumping the pedal on a carb engine does because there is no accelerator pump on a EFI setup.
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
