Did any TPI bases fit pre-86 heads?
Old Aug 28, 2013 | 01:55 PM
BirdofFireBOB's Avatar
Car: 88formulatp1
Engine: 5.0
Transmission: 5
Just pulled a 350 TPI out of an 89 Formi and I've got a perfect engine with pre 86 heads if I can find a TPI base for the early heads.. Help!
Old Aug 28, 2013 | 02:07 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Did any TPI bases fit pre-86 heads?
Elongate the center holes on a 87-88 89-92 base or a 85-86 base is a direct bolt on.
http://www.hotrodlane.cc/Streetstories/choosetpi1.htm
Old Aug 28, 2013 | 11:10 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
..or a 85-86 base is a direct bolt on.
And any TPI base from a 85 - 91 Vette which kept the early bolt angle
(if you are not worried about EGR hookup )
Old Aug 28, 2013 | 11:23 PM
Engine: Lb9
Transmission: M20
The vette intake has the center exhause feed for the egr as well as the rear feed but you would need a lock off plate for the rear egr feed
Old Oct 20, 2013 | 09:41 AM
87redformula's Avatar
Car: 89 FIREBIRD FORMULA 350
Engine: 355 ported 113 heads
Axle/Gears: 3.23 10 bolt form 2000 T/A
the edelbrock 3860 fits both. the center holes are machined for both angles and give special washers to use. I just put this intake on a 355 build with 113 vette heads. Im pretty sure the holley stealth ram is the same way also but you would have to double check that.
Old Oct 20, 2013 | 10:29 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
If you don't want to modify the center holes on an 87+ intake I've got an 85-86 TPI intake available..... Just send me a PM with your ZIP code if your intrested.
1992rs/ss
Jan 31, 2025 05:10 PM
Vintageracer
Jan 10, 2020 05:33 PM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
89-S-dime
Aug 12, 2015 11:57 AM
