Need complete 1989 Iroc 350 tpi under dash wiring harness diagram
Old Jul 30, 2013 | 12:26 AM
duece's Avatar
Car: 1990 Iroc Z convertible
Does anyone have a complete 1989 Iroc 350 tpi under dash wiring harness diagram.........?
I need it from the fuse box all the way to the other side of the car to the C207 connector
I need to fix some wires.......
thanks in advance
Old Jul 30, 2013 | 12:54 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Need complete 1989 Iroc 350 tpi under dash wiring harness diagram
Problem is there is generally not one diagram for a harness.
The diagrams are usually broken down by the individual circuits as shown in these '86 wiring links
http://92b4crs.tripod.com/86wiring/86wiringindex.html
Old Jul 30, 2013 | 12:59 AM
duece's Avatar
There are three dark brown wires that come out of the c207 connector and head toward the driver side of car.........I need to know where they go as all three are exactly the same.....and mine are all cut
Old Jul 30, 2013 | 03:23 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
the c207 connector
Maybe you should do a search for the C207 pinouts ?
Several to be found on here
https://www.thirdgen.org/forums/post...708-post9.html
Old Jul 30, 2013 | 07:51 PM
duece's Avatar
I followed the wires(dont ask me how) and one wire goes to the fuse box(F/P-Fan-C/H fuse location), one wire goes to the back of the right side(brown)connector(pin 8) behind instrument cluster, and one goes to the ALDL connector(pin C).....
I need to know which of these matches up with c207 pin outs A, D. and K.............
Old Aug 5, 2013 | 03:29 PM
duece's Avatar
bump
Terrell351
Jun 13, 2021 01:13 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
Reddeath210
Oct 6, 2015 08:20 AM
kyleb24
Aug 15, 2015 08:24 AM
mustangman65_79
Aug 11, 2015 03:17 PM
