No oil pressure til restart engine
Old Aug 4, 2013 | 08:23 PM
kitt462d's Avatar
Car: 1985 TA
Engine: 350 Carb
I was driving my 85 TA 5.0tpi today and all was good. until about 15mins into the drive oil pressure on stock gauge dropped to 0. I pulled over and heard no odd sounds and checked to see if i had oil and it was ok. went home and shut the car off. within 5 minutes restarted it and normal pressure. waited 3 hours and normal pressure again. not sure where to start with this. all other gauges are fine. except temp. as i put in a mechanical unit.
Old Aug 4, 2013 | 08:37 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: No oil pressure til restart engine
How do you know the gauge is working correctly.
All it takes is a bad / loose wire to give the situation you have
Only way to confirm what is actually happening is to temp install a mech OP gauge
Old Aug 4, 2013 | 10:23 PM
kitt462d's Avatar
Car: 1985 TA
Engine: 350 Carb
[quote=vetteoz;5612891]How do you know the gauge is working correctly.
Only way to confirm what is actually happening is to temp install a mech OP gauge[/quot
Good point. I just assume it was ok as it always seemed accurate and didn't bounce or anything odd when it quit. then just worked fine at a restart. I figured if it was bad it would just quit all together. But I thuink youre right to be sure and at least eliminate that. Thanks a lot
Old Aug 6, 2013 | 01:27 PM
kurtis72's Avatar
Car: 83 & 91 Z28 + others
Engine: l69 & lb9
Transmission: t-5
I have a 92 blazer and the oil pressure would go almost to 0 sometimes. I fixed it by removing the dash cluster and cleaning the connector, re-installed it and now it is fine. Free fix, just took some time to disassemble the dash.
Old Aug 6, 2013 | 01:42 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
This happened to me. I was about 2 miles from home when I noticed that I had no oil pressure. Even though I heard no rattles, knocks or any other noise coming from the engine, I immediately pulled into a parking lot and shut it off. I got out and checked oil level, which was fine. After not finding anything and knowing that I had a full oil pan, I started it up and it showed full oil pressure. I drove it home and while checking it out, found a little oil leakage on the sending unit. I replaced that sensor and have not had a repeat of the problem in over 3,000 miles.
Old Aug 6, 2013 | 02:51 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
I would guess sensor issue if all else is good. You can verify with a mechanical gauge if you are worried. Those senders tend to fail or leak or have a mind of their own after a while.
You'd know pretty quick if you really had zero oil pressure. Probably would hear some fun noises, feel the engine get sluggish, and eventually you'd have some knocking. Wouldnt take too long.
J.
db057
Aug 22, 2015 08:17 PM
Navy8125
Aug 21, 2015 09:32 AM
bamaboy0323
Aug 15, 2015 07:20 AM
ChevyZ71
Aug 13, 2015 07:30 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
