89' TPI has a hard time accelerating after manifold and injector swap
Car: 1989 Firebird Formula 350
Engine: 350 TPI L98
Axle/Gears: 3.91
Hey guys,
Im at a complete lost here, so over the weekend I installed a ported stock 89' manifold base and Bosch III 22 pound per hour injectors with a adjustable fuel pressure regulator on my L98. So after fire up we got the timing set back to 6 degrees btdc and seemed to be idling, reving and starting fine, but when putting it in gear it has the hardest time accelerating from a stop until 2k it gets a little better but you can feel the power isnt there and felt like its being held back. When it warms up it gets better but still feels laggy. I had the fuel pressure set to 46 at wot and today i noticed it was at 40 at wot so i just tried to set it to the recomended max of 50 and then after fire up the gauge went to 0 and never moved. And also today i noticed it backfires through the exhaust and intake tube when barely cracking the throttle body open. And now its running worse than ever.
What I did so far:
tightened all the runner bolts and vacuum lines
checked timing to see if its at 6 degrees (which it is)
looked for arcing plug wires
made sure all the injectors are pulsating (which they are)
use a temp gun on each header tube and they all read around the same temp
Reset the ECM
So guys any kind of help would be appreciated
What I did so far:
Reset the ECM
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: 89' TPI has a hard time accelerating after manifold and injector swap
You set the timing with the est lead disconected I hope. Otherwise you may be too rich and need a chip burnt.
Car: 1987 Z28 IROC
Engine: 6.2L
I second a timing issue. Either timing was set with est lead still connected, or if you did disconnect it, you haven't re-connected it. Could the distributor be out a tooth?
Engine: 350 TPI L98
Axle/Gears: 3.91
Yes it was the timing I thought we disconnected the EST but I guess we didn't. Disconnected the timing was at -4 haha.
Well thanks again guys I really appreciate it
