Good Things to replace while intake/fuel rails are off?
Old Aug 5, 2013 | 11:29 PM
penguinpanda0's Avatar
Car: 1987 IROC-Z Camaro
Engine: 305 LB9
I'm switching over to the bosch iii injectors (got em from southbay, they are stamped Ford on the side? Explanation?), and I'm wondering what are some good things to replace that wouldnt be so convenient to replace otherwise? So far, I'm thinking:
-Manifold Air Temp Sensor
-EGR Valve (Any way to test if my current one needs replacing?)
Any other things I should replace while I'm at it?
Old Aug 7, 2013 | 02:01 PM
tpi84stepside's Avatar
Re: Good Things to replace while intake/fuel rails are off?
Only replace what is broken...When you change to many parts at once it makes it very difficult to diagnose a problem. Many new parts today are junk right out of the box.
Old Aug 7, 2013 | 04:11 PM
nomind's Avatar
Car: 85 Trans Am
Engine: LB9
Transmission: Finally Fixed (T5)
I just did the same thing. I redid the gaskets for the intake runners/plenum/TB, and I put in a new thermostat. Spent a fair bit of time cleaning stuff. Otherwise, if its not broken....
Ghettobird52
Jul 5, 2024 11:18 PM
camaro71633
Sep 1, 2015 10:24 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
Bob88GTA
Aug 18, 2015 03:31 PM
