355 Opinions
Old Aug 14, 2013 | 01:26 PM
racerx520's Avatar
355 Opinions
Got back from the machine shop today, they told me the only thing to do with my motor is to bore it .030 over or do a 383. I'm looking for opinions on any parts to do for the 355 since 383 is way out of my price range. I'm going to spend a while and maybe up to 1500 (parts and boring) on the motor. Just looking for peoples opinions or suggestions.
Thanks.
Old Aug 15, 2013 | 10:21 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: 355 Opinions
Thanks.
hey if all you need to do is bore and hone it,AND your crank and rods are ok (have them sonic checked) you can build a fine 355 with cast flat top pistons and iron rings. this is done regularly for around $600. good luck
Old Aug 16, 2013 | 09:03 AM
racerx520's Avatar
Re: 355 Opinions
hot tank (since it was under salt water) is $200, bore out and hone is $303, crank cut and polish (cuz summit shows 355 kits with .030 over pistons and .010 under crank bearings) is $158. So i'm looking at about 600 for just the machine work. the rebuild kits are about 600 on summit.
Old Aug 16, 2013 | 11:49 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 355 Opinions
crank cut and polish is $158.
So you would spend $160 to put the old 350 cast crank back in when for $30 more you could have a 383 with a steel crank using std size bearing ?
http://www.summitracing.com/parts/es...3750/overview/
Maybe a hours extra labor to clearance the block for the stroker crank , something you could even do yourself at home for free
Hey ,for #$30 more I would put a new steel crank in even if I was only building a 355
http://www.summitracing.com/parts/es...3480/overview/
Old Aug 17, 2013 | 05:49 AM
racerx520's Avatar
Re: 355 Opinions
I thought almost any .030 over kit i saw on summit said the main bearings cam .010 under anyway. ?
Old Aug 17, 2013 | 05:46 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: 355 Opinions
Most offer various different OS piston and std/ undersize bearing combos , like this
http://www.summitracing.com/parts/fe...make/chevrolet
The 10 under bearings come with the 30 over kit because in most cases a engine worn out enough to need boring out usually need a crank regrind it
refitting the original crank.
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
cheesehomer
Dec 31, 2015 08:48 AM
darwinprice
17
Oct 11, 2015 11:51 PM
Jlanz55
Sep 29, 2015 08:55 AM
