no start
Old Aug 15, 2013 | 06:15 PM
lakeport's Avatar
Car: 1988 GTA Trans AM
Transmission: 5 speed
no start
Driving home tonite, car sputters and shuts off, wont restart, just cranks, n cranks. I was down to a 1/4 tank, was stopn for gas when this happened, thought maybe gas gauge was busted so got a can and put gas in it, just cranks, got it towed home
now looking for ideas, check spark and fuel pressure? I know theres gas in rail as if u push on Schrader valve it squirts gas
what pressure readn should it be when cranking?
any other ideas to check? fuses? relay?
Car is a 1988 GTA Trans AM, 305 TPI, 5 speed
thanks in advance to all
hooked up fuel pressure gauge, turned key to on, gauge went to 42, it dropped to 20 within 6 minutes, so doesn't seem to hold , but it is getn gas
Old Aug 15, 2013 | 07:19 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: no start
Originally Posted by lakeport
gauge went to 42,but it is getn gas
Rail pressure is fine but does not mean the engine is " getting gas "
Pull a spark plug out, if it is wet you " have gas" ; if not the injectors are not being fired.
Test for injector pulse at the inj connectors using a noid light
If plugs are wet with fuel , check for spark
How to here.
http://easyautodiagnostics.com/gm_ic...n_module_1.php
Also read
https://www.thirdgen.org/forums/tech...formation.html
Old Aug 19, 2013 | 08:56 AM
lakeport's Avatar
Re: no start
So i got a spark plug tester, found no spark, decided to swap the ICM that I replaced last summer, car started, replaced with a new ICM under warranty, and all is good to go
many thanks for the help
Old Aug 22, 2013 | 11:13 AM
DRIVE2FAST's Avatar
Car: 90 IROC 5.7 1LE CLONE 89 GTA 88IROC
Engine: 5.7TPI / 5.7TPI/ 5.7TPI/ 4.3 CMFI
Transmission: 700R4 UPGRADED 700R4STOCK700R4STOCK
Axle/Gears: 3.23 10 BOLT 3.27 9 BOLT 2.77 9BOLT
Re: no start
WAS IT THE IGN MODULE UNDER THE DIST CAP ?
I CARRY IGN MODULE WITH ME. SAVED ME IN THE PAST.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
