Best ECM for retrofit
Old Aug 18, 2013 | 10:32 AM
ToolGuru's Avatar
Car: 1969 Camaro SS
Engine: 355, roller, Profilers, FIRST tpi
Transmission: 200r4
Have an 88 'Vette TPI system. Of course, the idiots cut the harness at the firewall, so I need a computer to retrofit on my 69 Camaro. Would like to eliminate the ninth injector and more than likely go to speed density instead of the MAF. If going to speed density is the right move, which GM ECM do I want to be looking for. IF MAF is better for a retrofit, which ECM is the one to get? Going to be putting a fully ported TPI unit on a 375 HP 350. Thanks in advance.
Old Aug 18, 2013 | 07:28 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Best ECM for retrofit
The '730 (GM # 1227730 ) MAP ECM
May also be numbered 16196344 16198262 or 88999196
The tune you put on the removable memcal (chip ) inside determines what it's final usage is so what it came out of originally does not matter
Used with many different GM cars /engines , examples
6000 87-89 Elec Cont Unit (ECU); 6-173 (2.8L)
6000 89-91 Elec Cont Unit (ECU); 6-191 (3.1L)
BERETTA 87 Elec Cont Unit (ECU)
BERETTA 88 Elec Cont Unit (ECU); 4-121 (2.0L), thru VIN 500000
BERETTA 88-89 Elec Cont Unit (ECU); 6-173 (2.8L)
BERETTA 90-91 Elec Cont Unit (ECU); 6-191 (3.1L)
BERETTA 92-93 Elec Cont Unit (ECU); (above right kick panel), 6-191 (3.1L)
CAMARO 90-92 Elec Cont Unit (ECU); 6-191 (3.1L)
CAMARO 90-92 Elec Cont Unit (ECU); 8-305 (5.0L), MFI
CAMARO 90-92 Elec Cont Unit (ECU); 8-350 (5.7L)
CAVALIER 87 Elec Cont Unit (ECU)
CAVALIER 88-89 Elec Cont Unit (ECU); 6-173 (2.8L)
CAVALIER 90-93 Elec Cont Unit (ECU); 6-191 (3.1L)
CELEBRITY 87-89 Elec Cont Unit (ECU); 6-173 (2.8L)
CELEBRITY 90 Elec Cont Unit (ECU); 6-191 (3.1L)
CENTURY 87-88 Elec Cont Unit (ECU); 6-173 (2.8L)
CIERA 87-89 Elec Cont Unit (ECU); 6-173 (2.8L)
CIMARRON 87-88 Elec Cont Unit (ECU)
CORSICA 87 Elec Cont Unit (ECU)
CORSICA 88 Elec Cont Unit (ECU); 4-121 (2.0L), thru VIN 500000
CORSICA 88-89 Elec Cont Unit (ECU); 6-173 (2.8L)
CORSICA 90-91 Elec Cont Unit (ECU); 6-191 (3.1L)
CORSICA 92-93 Elec Cont Unit (ECU); , 6-191 (3.1L)
FIREBIRD 90-92 Elec Cont Unit (ECU); 6-191 (3.1L)
FIREBIRD 90-92 Elec Cont Unit (ECU); 8-305 (5.0L), MFI
FIREBIRD 90-92 Elec Cont Unit (ECU); 8-350 (5.7L)
FIRENZA 87 Elec Cont Unit (ECU); 4-121 (2.0L), w/o OHC
FIRENZA 87 Elec Cont Unit (ECU); 6-173 (2.8L)
SKYHAWK 87 Elec Cont Unit (ECU); (4-121, 2.0L), w/o turbo; w/o OHC
SUNBIRD 91-93 Elec Cont Unit (ECU); 6-191 (3.1L)
TEMPEST 87 Elec Cont Unit (ECU)
TEMPEST 88 Elec Cont Unit (ECU); 4-121 (2.0L), thru VIN 500000
TEMPEST 88-89 Elec Cont Unit (ECU); 6-173 (2.8L)
TEMPEST 90-91 Elec Cont Unit (ECU); 6-191 (3.1L)
Old Aug 18, 2013 | 07:40 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
the idiots cut the harness at the firewall, retrofit on my 69 Camaro. .
From experience I highly recommend you buy a aftermarket standalone harness to suit whatever ECM you choose ,
for a perfectly tidy install and less frustration whilst gutting all the redundant wiring out of a original harness
Make sure any harness you get has the speedo (VSS ) connection ; some of the cheaper ones do not
http://www.ebay.com/itm/TPI-Speed-Density-MAP-wiring-harness-for-1227730-/141029051080?pt=Motors_Car_Truck_Parts_Accessories&hash=item20d5fc8ac8&vxp=mtr
Old Aug 19, 2013 | 08:03 AM
ToolGuru's Avatar
Car: 1969 Camaro SS
Transmission: 200r4
TPI Speed Density Map Wiring Harness for 1227730 | eBay
Yeah, was going to do that. Since I am in Michigan, I was going to look very closely at Howel Engineering. Thank you for providing another source for comparison.
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
