TPI swap first start checklist
Old Aug 30, 2013 | 05:18 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
I just swapped TPI back onto my 1985 Camaro and have everything hooked up and I think ready to go. Before I try cranking it over does anyone have a checklist of things to go over in case I forgot something?
The engine in the car isn't new so I don't have to worry about priming the oil, it last ran 2 weeks ago.
Old Aug 30, 2013 | 10:06 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: TPI swap first start checklist
Temporaily hot wire the pump to run full time on it's own (jumper the pump relay connector ) and key OFF
check for fuel leaks on the fuel lines to / from the engine and the injectors / fuel rails before you crank it over.
Old Aug 30, 2013 | 10:21 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
I cycled the key on and off for the fuel pump prime 4-5x and checked for leaks but I will energize the pump and let it run while looking for leaks.
I was a bit nervous about the FMS 24lb injectors I installed. I put them in the fuel rail first all the way seated, but when I put the electrical connectors on them my SLP runners got in the way. I had to float a couple of injectors to make them work. I think it was the #7 and #2 I had to do that for.
Also the steel feed and return fuel lines are about 1/2" from the driver's header. Will that be too much heat? The lines are secured to the body so it will be difficult to move them away anymore.
I was planning on just running straight water for the initial start up and test in case of leaks. Any problem with that?
Wade787b
Sep 29, 2015 01:15 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
mizz0313
Aug 12, 2015 06:45 AM
drathaar907
Aug 6, 2015 04:20 PM
