Where to find OEM STOCK PROM?
Looking for a stock oem prom that isnt anything programmable or high performance, etc. Have a code 51 with a brand new ecm and the same prom, so assuming the prom is bad. All im finding is performance or programmable or used stuff on ebay. I would rather pay a bit more to have a new oem one than a used oem one.
Sort of new to the TPI engines and trying to get my 91 camaro running good again.
Thanks.
Thanks.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Where to find OEM STOCK PROM?
I have several memcal and maybe able to refurbish yours. I have only seen 2 memcals fail and they bolth had the same issue a prom bit flip so it actually lost a electrical charge and the hex data changed bye a value. I have tpi 305, 350 manual, automatic as well. If this is a 305 automatic the axxb is still available through amazon.
Ill have to surf amazon to see what i can find. Not 110% sure what im looking at when i find it even. Its a 305 automatic car. It has had a new ECM put in with the old prom and the problem still exists and i still have a code 51 which says either prom or ecm are bad. Like i said im not 110% sure whats what with the tpi prom stuff, but reading alot and trying to figure it out. Just want the car to run good because i have sold my truck and am going to be relying on this to drive me to work daily in a few days when the truck leaves.
Engine: Lb9
Transmission: M20
send me a pm if you want me to take a look at your old one
Engine: Lb9
Transmission: M20
No wonder The AUJW is a 3.1L gm/acdelco 16150975 Joined: Dec 2004
Engine: Lb9
Transmission: M20
Azty coming your way priority , lmk how it works
1989formula5.7l
Aug 17, 2015 02:56 PM
Sanjay
Aug 12, 2015 03:41 PM
