tpi harness conversion question
Car: 91 Camaro RS
Engine: 305 TPI conversion.
im in the middle of dropping in a tpi from an 86 to an 88. the car belongs to a friend. the 88 originally was a tpi but a p/o converted it to carb. the ecm have the same numbers. however there seems to be an extra plug on the 86 harness. I see where it plugged in on the donor car, but there is no plug in on the 88. its attached in the same area as the ecm connectors are.
what did this plug into? im not sure if it is not on the 88 or if it was removed.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: tpi harness conversion question
A picture of the connecter with the wire colors may help.
Car: 91 Camaro RS
Engine: Lb9
Transmission: M20
That is injector power and vss signal. pink wires will be fused 10 amp .
The brown wire is for the cooling fan relay.
Car: 91 Camaro RS
so this connector should originally be intact on this car? it was a tuned port. ill have to get undetr there and either find it or its wires if so.
Engine: Lb9
Transmission: M20
Im pretty sure its part of the interior wiring it goes behind the dash and the two pink wires goto the fuse box.
Car: 91 Camaro RS
i still have the donor car. if i have to ill pull it out and wire it in.
Car: 91 Camaro RS
anyone else with an 88 that has it or not? i want to make sure before i cut and modify, and that its not been rewired elsewhere.
Car: 1987 Z28 IROC
Engine: 6.2L
Yes that plug is factory and supposed to be there. I have one in my 1985 305 TPI car. That one looks like it is from the ECM side. The one attached to the car should be the pin socket.
Car: 91 Camaro RS
anything is possible. ill double check again this weekend.
Car: 91 Camaro RS
anyone with an 88 tpi please check your harness for this car. for whatever reason, it is not part of the harness from the fuse panel to the ecm. there are no cut wires or any other proof it was here. I need tov make sure. if not where do I wire this in on the fuse box?
Engine: Lb9
Transmission: M20
The pnk/black ones go to the fuse box injector 1 and injector 2 , 10 amp fuses .
The brown needs to tied into load side of c/h (A/C-heater) fuse in existing fuse box.
Car: 91 Camaro RS
ok thanks. im trying to help a friend get this car on the raod. its aggravating as hell right now.
I also have to splice the fuel pump connector to the wires on the tank. by chance do you have a diagram? black goes to black, but ive got pink and tan/white on the connector and a purple and grey wire from the pump.
thanks
thanks
Engine: Lb9
Transmission: M20
http://www.austinthirdgen.org/index.php?pid=19
the purple is the fuel sender, pink is fuel pump power IIRC it changes to grey c201
Sanjay
Aug 12, 2015 03:41 PM
