NEED TUNERPRO HELP
Old Aug 23, 2013 | 02:00 PM
DRIVE2FAST's Avatar
Car: 90 IROC 5.7 1LE CLONE 89 GTA 88IROC
Engine: 5.7TPI / 5.7TPI/ 5.7TPI/ 4.3 CMFI
Transmission: 700R4 UPGRADED 700R4STOCK700R4STOCK
Axle/Gears: 3.23 10 BOLT 3.27 9 BOLT 2.77 9BOLT
NEED TUNERPRO HELP
ANYBODY HERE GOOD WITH TUNERPRO RT . I NEED THIS STUFF TO WORK AND ITS NOT WORKING. LOTS OF ERROR MESSAGES AND %^@#@^$#
NOT GETTING ANY ANSWERS FROM TUNERPRO HELP WEBSITE.
Old Aug 23, 2013 | 02:23 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: NEED TUNERPRO HELP
This post should be in DIY prom or ecm section, your not stating the issue your having but check your driver status first and make sure you are loading the $8d adx assuming your wanting to datalog. you can convert the ads on tp site or download the adx from the 1227730/1227727 $8D section of gearheadefi.com
Old Aug 23, 2013 | 03:11 PM
DRIVE2FAST's Avatar
CAR : 1990 IROC-Z
ENG : 5.7 TPI HOOKER 2055 SHORT HEADERS 3 " EXHAUST NEW CAT A/C DELETE
700R4 WITH HARD SHIFT MODS
NEW PARTS : DISTRIBUTOR / IGN COIL / P/U COIL / IGN MODULE / CTS / O2 SENSE / FUEL PUMP / FUEL FILTER
SET TIMING TO FACTORY SPEC 6* CAR IN DRIVE TAN/BLK WIRE DISCONNECTED / A/C OFF(DELETED)
PASSED EMISSIONS RUNS SMOOTH AND STRONG
CURRENTLY CRANKS / FIRES AND IMMEDIATELY DIES. WILL RUN AND DRIVE IF THROTTLE PLATE OPENED A SMALL AMOUNT TO IDLE ENG.
I SUSPECT THE IAC VALVE. WHEN I REMOVED IT FROM THE THROTTLE BODY THE PINTLE EJECTED . IT HAD VERY LITTLE THREAD ENGAGEMENT. SEEMS LIKE IT WAS JAMMED EXTENDED ( CLOSED) I AM CURRENTLY CLEANING IT AND THE IAC PORT ON THE T/B. WILL RE INSTALL SHORTLY.
BIN FILE : ANJF 90 F-CAR 5.7TPI 700R4
BIN DEFINITION FILE : Super_8dm2.ecu
ALDL DEFINITION FILE : 1227730_8D.ads
THE TUNERPRO PROGRAM WANTS A .XDF BIN DEFINITION FILE AND THE TUNERPRO WEBSITE LISTS Super_8dm2.ecu AS THE BIN DEFINITION FILE FOR L98 1990. IT REJECTS IT WHEN I SELECT IT FROM THE SELECT .XDF MENU.
THE OTHER DEFINITION FILES FOR DIFFERENT TYPE ENGS AND MODEL YEARS ARE .XDF FILES SO I DONT GET IT.
CURRENTLY I CANT EVEN LOOK AT THE DATASTREAM. KEEP GETTING VARIOUS ERROR MESSAGES ( COM PORT ERRORS ) AND MISMATCHED .XDF ERROR MESSAGE
I NEED THIS STUFF TO WORK SO I CAN AT LEAST ATTEMPT TO DIAG.
ANOTHER DAY STUCK ON AN ISLAND OF BROKEN DOWN CARS. @$#@#$ BAD LUCK.
Old Aug 23, 2013 | 03:23 PM
Engine: Lb9
Transmission: M20
you dont need a binary program to datalog.
File Type: zip
Old Aug 24, 2013 | 07:49 AM
DRIVE2FAST's Avatar
I NEED IT FOR COMMAND AND CONTROL FUNCTIONS ( IAC / SPARK ADVANCE / FUEL / EGR ETC...
Old Aug 24, 2013 | 01:22 PM
Engine: Lb9
Transmission: M20
No needd to yell you didnt state you were emulating AUJP is superseded com ANJF.
Old Aug 25, 2013 | 03:29 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
I don't think he is trying to yell, just the way he types. Would help if you take the caps lock off though, little easier to read.
For the Super_8dm2.ecu file problem I thought you just change the file type from .ecu to .XDF? If that don't work maybe just use any 8D.xdf
Old Aug 27, 2013 | 07:01 AM
DRIVE2FAST's Avatar
CAPS IS STUCK SORRY. IM OLD AND BLIND EASIER FOR ME TO READ.
Old Aug 27, 2013 | 08:12 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
To load an ECU file use the Import selection in the XDF drop down menu. Once imported you can save it as an XDF file.
RBob.
Old Aug 27, 2013 | 10:43 AM
DRIVE2FAST's Avatar
RBob.
THANX ILL TRY IT.
IF I KNEW HOW USER UN-FRIENDLY THIS PROGRAM WAS GOING TO BE I WOULD HAVE FOUND A GM TECH II SCANNER.
MOATES AUTO PROM WILL MOST LIKELY JUST **** ME OFF. ANOTHER DAY...
Old Aug 27, 2013 | 12:25 PM
Engine: Lb9
Transmission: M20
join, Gearhead efi . Mark has composed alot of write ups on TP if your not finding it user friendly.
Old Aug 31, 2013 | 08:17 PM
DRIVE2FAST's Avatar
I WILL DO THAT. OR SWITCH TO CARBURATION.... LAFF
junkcltr
26
Jan 22, 2022 10:53 AM
Mark_ZZ3
May 24, 2018 01:02 PM
ULTM8Z
Oct 2, 2015 01:25 PM
GTAman
Sep 21, 2015 09:57 AM
tmellott89
Aug 16, 2015 02:58 PM
