85 tpi harness frustration
Old Sep 14, 2013 | 04:02 PM
TBRays98's Avatar
Car: 1989 Formula
Axle/Gears: 3.45 1LE Disc LSD
Ok im still trying to figure this out but i now know the 85 tpi was an odd year.
The interior harness to the engine harness is slightly different.
Is there and way around not using an 85 engine harness?
I would like to use a newer harness with a serp setup instead.
If i can use a newer harness how can i go about this without swapping out the whole interior harness?
Old Sep 14, 2013 | 06:42 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 85 tpi harness frustration
You can use ( with work ) the 86 - 89 TPI computer on the 85 wiring harness
See
http://www.eecis.udel.edu/~davis/z28/ecm_swap/
The harness has no relationship to the accessory drive being used
Old Sep 14, 2013 | 06:47 PM
TBRays98's Avatar
Car: 1989 Formula
thanks for the information, i dont know how to re pin but ill look into this
stalkier
Dec 6, 2015 11:25 PM
Hawkeye1980
Aug 31, 2015 07:09 AM
IBrockZ
Aug 20, 2015 12:20 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
