code 42
Car: 87 TA
Engine: 305 tpi
Transmission: auto
code 42
The car is an 87 trans am 305 tpi auto. I am getting a code 42 after the engine temp reaches 190 roughly.
When the code sets the engine feels sluggish/lacking power, backfire in muffler after letting off the gas. Also the temp runs 20 degrees higher than normal, the idle feels okay. Taking off from a stop the engine feels bogged down until i get to 10? mph then feels like it has more power.
I went through the service manual flow chart for code 42. I got 556 ohms on curcuit 423?(don't remember exactly, but the white wire coming from icm) the manual says no more than 500. The white wire(ohmed out good) and connections look good. Replaced icm with a new one that tested good 3 times in a row and the car wouldn't even start with that one.
Any input on my next step would be greatly appreciated
Car: 87 TA
Engine: 305 tpi
Transmission: auto
Re: code 42
also had the tach go wild when crusing at 2000 rpm, it would jump from 1000 to 4000. It stopped after a couple of miles.
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Re: code 42
make sure the tac lead is not grounding on the coil
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Re: code 42
Did this ever get fixed? Im having a stupid code 42 and looking for some things to check
Car: 87 TA
Engine: 305 tpi
Transmission: auto
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
