Adjustable Fuel Pressure Regulator Question
Car: 1989 Firebird Formula 350
Engine: 350 TPI L98
Axle/Gears: 3.91
Hello,
I have installed a adjustable fuel pressure regulator when I did my injector and manifold swap.
At first it was running good but once i installed a gauge it reads 50 psi at idle with the vacuum line connected. Now I know it isnt suppose to be that high and when i unplug the vacuum line it only goes up to 52 psi.
Any ideas on what could be causing this? Do you think I have another problem somewhere else?
I just need some insight.
Thanks,
Everyone
Thanks,
Everyone
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Adjustable Fuel Pressure Regulator Question
the pressure is not set out of the box
9192camaro
16
Feb 3, 2019 12:21 AM
