Setting timing
Old Oct 5, 2013 | 09:15 AM
cmk-2's Avatar
Car: Corvette ZR-1
Engine: LT-5
Transmission: 6 sp
Setting timing
Hello,
When you set the timing on a 87 TPI do you put the transmission in Drive? I know on my 1978 Trans Am You put it in drive to read and set the timing but nothing I have read has said anything about that.
Thanks again,
Old Oct 5, 2013 | 09:54 AM
Re: Setting timing
Doesn't matter, as long as the engine is running fairly slow. You may well find however that in "timing set" mode, when it's missing about 20 - 25° of advance, it won't even run in gear at all.
Didn't matter in a 78 either, for that matter; as long as the RPM was below the point where the mech adv started operating.
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
