Yet another cam question.. ur thoughts please.
Old Oct 8, 2013 | 04:37 PM
Copchaser's Avatar
Car: 86 Trans am, 91 Camaro RS
Engine: 355 Sbc, nothin yet
Transmission: 700r4- both
So the wife has decided she doesnt want her 91 RS to be a bat outta hell. In my mind im thinking "then why am I even building this thing?" Nonetheless, I have narrowed down my parts list. I need some advice on the Howards 180235-14 cam. Does anyone have experience or no how well these cams run? Most tpi runners are in the Comp, Crane, and GM world for most builds. I wanted to try something a lil different here. Any advice would be appreciated.
355 2 bolt
Hyper flat tops
PC 190cc heads
Hooker 2055s
Factory tpi setup... for now
3.42 gears
Cam specs..
Advertised Duration266 int./270 exh.
Basic Operating RPM Range1,000-5,000
Cam Style - Hydraulic roller tappet
Camshaft Gear Attachment - 3-bolt
Camshaft Manufacturers Description - Good idle, broad power range with strong mid range performance.
Computer-Controlled Compatible - Yes
Duration at 050 inch Lift 213 int./217 exh.
Lobe Separation (degrees)114
Valve Lift with Factory Rocker Arm Ratio 0.485 int./0.495 exh.
Old Oct 8, 2013 | 11:24 PM
Copchaser's Avatar
Re: Yet another cam question.. ur thoughts please.
Anyone?
Old Oct 9, 2013 | 08:11 AM
Abubaca's Avatar
That cam should work real well, but I don't know anything specifically about Howard's. I know my stock 89 MAF system handled the slightly larger zz4 cam no problem, but not sure how the 91 SD system is gonna react to that cam.
...and those heads might be a little big for a tpi. I know the socal guys are running big heads and cams, but they also have heavily modified intakes to support it. You're probably better off with a smaller head that can help you with torque under the curve.
Old Oct 10, 2013 | 04:33 PM
Copchaser's Avatar
Well the original plan was to run a "slightly" bigger cam originally. Thats where the bigger heads would come in. Also I would see more of a benefit should I decide to port the base, runners etc. I just thought I would look at some different cams out there and see what was avail before I resorted back to my original plan. Plus this howards cam has "roughly" the same characteristics of the LPE 211/219 cam.
Old Oct 10, 2013 | 04:39 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
It will be fine. Should be torquey
Rather see more lift but those lobes should be softer on valvetrain and springs last longer
Old Oct 11, 2013 | 12:30 AM
Copchaser's Avatar
Thanks Orr, im not goin crazy on this build, my other one has the fun stuff in it. Jus wanted something slightly better than a stock LT1. But with good mileage as well as some decent low end grunt. I have a set of comp 987 valve springs that I was gonna use since the cam has low lift, even with a 1.6 rr. U think I will be safe here?
Old Oct 11, 2013 | 08:37 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
With Orr that cam will run good with the TPI/heads you have.
Porting the intake will help even more get some good runners on there, headers it will pull like a stroker.
Old Oct 11, 2013 | 09:12 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
987's will do fine
Old Oct 11, 2013 | 11:15 PM
Copchaser's Avatar
great!! thank you fellas. I think ima try this as opposed to the "usual" cam choices. Ill update u guys when its runnning
CarGuyDennis
137
Dec 6, 2016 11:02 PM
gta90
Sep 15, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
cougar20th
Aug 27, 2015 08:04 AM
86White_T/A305
Aug 17, 2015 12:16 AM
