GM Flow tests (stumbled on website)
Old Oct 22, 2013 | 09:02 AM
ratfink6923's Avatar
Car: 15 Ram, 88 IROC, 92 RS
Engine: 5.0
Axle/Gears: 3.42 (4th Gen)
This may be posted somewhere here already, but I found it handy. I googled the part number on my injector, and this page was the first link. Great information
http://gmtuners.com/flow/
Old Oct 30, 2013 | 09:08 PM
Jersey89GTA's Avatar
Car: 90 Iroc Vert
Engine: 5.0L
Re: GM Flow tests (stumbled on website)
I can add to that, this is a video of injector testing before and after cleaning.
Found it interesting. Enjoy
Old Nov 1, 2013 | 10:28 AM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Thanks for posting that. Good info to have. I didn't know the stock TPI throttle body flowed that much. Makes me believe my 52 MM TB is too big for my nearly stock 350 TPI. Problem is, I can;t find anyone that rebuilds the TB.
Old Nov 1, 2013 | 01:53 PM
Engine: 5.0
Why does your tb need to be rebuilt? leaking past the blades? Any good carb shop should be able to remedy that
Old Nov 2, 2013 | 06:08 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by Fred SS
I cant find anyone that rebuilds the TB.
Several online sources
http://www.ebay.com/itm/TPI-52mm-bored-port-throttle-body-85-92-Z28-TA-Corvette-/230426189214?pt=Motors_Car_Truck_Parts_Accessories&hash=item35a6789d9e&vxp=mtr
Old Nov 2, 2013 | 06:13 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
The butterfly shafts run direct in the alum housing , there are no bushes so eventually the alum wears oval and the blade is no longer sitting in the correct position
Typically observed as the RPM " hanging up " when the pedal is released because the butterflies jam on the side of the bore and the pedal needs a hard tap in order to break them free and the idle to drop down.
Aftermarket rebuilders drill the shaft hole out and install bushes to correct the problem ( and make the TB last much longer )
Old Nov 4, 2013 | 12:10 PM
Fred SS's Avatar
Transmission: 2004r
Thanks for the link Vetteoz. I got two stock TBs and on both the shafts wobble.
Fronzizzle
Feb 9, 2017 09:31 AM
BumpaD82
Feb 26, 2016 02:57 PM
corey8084
Sep 17, 2015 02:56 PM
earlpote
Sep 12, 2015 11:55 AM
83 Crossfire TA
Sep 8, 2015 12:06 PM
