correct prom??
Old Oct 30, 2013 | 10:08 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
correct prom??
my 86 TPI camaro has the ECM #1227165. and it has the prom #AMU8958 in it my question of the day is: is this the correct prom ID for a car like mine?
Old Oct 30, 2013 | 11:22 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: correct prom??
Yes, that is the factory PROM. It is for an '86 Camaro, 5.0L TPI, auto trans, with both FED and CALI emissions. The only thing I don't know if it has been superseded. There may be a newer/better calibration for it as many of the early calibrations did get updated.
One update was to lock the TCC at a higher MPH. This was to prevent stutter at low speeds when the TCC would lock.
RBob.
Old Oct 30, 2013 | 11:27 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: correct prom??
https://www.thirdgen.org/forums/diy-...inal-prom.html
lethaldomestics
Sep 21, 2015 01:18 PM
BLK87Z
Sep 18, 2015 11:29 PM
ULTM8Z
Sep 16, 2015 09:15 AM
Winchester1094
Sep 15, 2015 09:48 AM
