Lt1 cam with 1.6 rockers
Old Nov 25, 2013 | 02:18 PM
lameusername's Avatar
Ok, I've searched and search and can't find an answer but I'm sure I'm not the only who has came up with this idea. But can anyone tell me if I can use the Lt1 stock cam with 1.6 rockers with the l98 heads? It's a tpi 350 setup. I'm asking because I'm worried about valve clearance. Any and all help is appreciated. Thanks!!
Old Nov 28, 2013 | 03:54 AM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Re: Lt1 cam with 1.6 rockers
It really depends on which LT1 cam it is. Most of them come with about .450-.470 lift and IIRC L98 heads don't like to go much past that without a little work done I.E. beehive springs, thinner retainers,seals. So with 1.6 rockers that would put you around .480-.501 lift. Maybe other can give you a better answer.
Old Nov 28, 2013 | 10:39 PM
I appreciate your info. That's along the lines of what I am looking for. So basically, if I want the 1.6 rockers, I need to have my heads worked on to accept that cam. Thanks!!
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
Cameeeero
Sep 18, 2015 04:00 PM
angel2794
Sep 8, 2015 06:22 PM
z28guy134
Sep 1, 2015 11:50 PM
