open loop status ?
Old Nov 25, 2013 | 08:31 PM
jordo2114's Avatar
open loop status ?
Hi, recently acquired an 89-irocz with the 305 tpi engine. I also bought some data logging cables from moates. Long story short when I am logging with the car and everything reaches temp and proper time the car is supposed to go into closed loop. In the tuner pro dash list there is a LOOP STATUS bit that always shows OPEN. Does this mean the car is stuck in open loop? The car runs great and gets good mileage about 23 if I baby it and the TCC seems to be working properly and the O2 shows voltage. The car does smell a little rich but I believe that is because the previous owner removed the cat. Any ideas? Thanks
Old Nov 26, 2013 | 04:24 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: open loop status ?
When static the O2 voltage should be about .45
The O2 voltage should rapidly change from low to high and back constantly when the sensor is operating correctly .If it doesn't the ECM will stay in open loop
Read
http://www.aa1car.com/library/o2sensor.htm
Old Nov 26, 2013 | 08:41 PM
DanielRicany's Avatar
On the L98s in order to go into closed loop the CTS must be 160 degrees F and the IAT sensor must be 140 degrees F. Probably the same on the 305.
Old Nov 27, 2013 | 06:17 PM
jordo2114's Avatar
Thanks guys
Old Dec 14, 2013 | 07:36 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Auto trans? Go into torque converter lock up? If so I think that shows closed loop.
Falcon50
Aug 22, 2020 03:26 PM
Pac J
May 17, 2020 10:44 AM
FueledSoul
Sep 29, 2015 08:58 PM
drumstixer
Sep 29, 2015 03:02 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
