87 TPI Cold Start Switch
Old Nov 30, 2013 | 11:10 AM
BrownBullet83Z's Avatar
Car: '83 Camaro Z28
Engine: "Just a little something"
Axle/Gears: 3:73
Hi All!!
Can anybody tell me and/or possibly display a cold start switch and where it is SUPPOSED to be on an 87 TPI?
I have a headache of a mess here and I am starting from square one. This motor is in a '42 Business Coupe and I am starting fresh because I cannot for the life of me figure out why this thing will not run. The injector is there as well as its connector/wiring however I do not see a switch anywhere. EVERYTHING (and I mean everything!) on this motor is brand new down to the ECM. It is NOT a VATS system and I did have it running when I first put it in but it is 700 miles away from me and that was 2 1/2 years ago! Any help would be appreciated.
Thanks in advance!
Oh Yea! If anyone has a pinout of C100 (@ the ECM) for an 87 TPI that would be awesome too. I have one however its on my other computer.... at home.... in Massachusetts...... 700 miles away!!! Thanks again!
Old Nov 30, 2013 | 12:29 PM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
Re: 87 TPI Cold Start Switch
Cold start switch is on the front of the manifold, next to the Coolant Sensor. It has a connector on it like a fuel injector connector (IIRC). Is is fused, but does not run through the ECM.
For your schematics, try here: (BTW, C100 is the firewall connector to the fuse box)
http://chevythunder.com/
Old Nov 30, 2013 | 04:18 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
The brass Hex head unit
Old Nov 30, 2013 | 04:36 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
The CSI only aids cold starting , it only works when the engine is cranking over and lack of it will not prevent the engine eventually starting
Old Nov 30, 2013 | 07:59 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
You can find the 87 C100 here:
http://berlinetta.info/C100.htm
You can also find the ECM/Dash C207 connector here:
http://berlinetta.info/C207.htm
As VettOzz said, "The brass Hex head unit" The Cold Start switch is circled in YELLOW in this pic. It should have a Purple wire and a Tan wire and like darbysan wrote; the connector will look like a fuel injector plug.
Power is applied thru the CRANK fuse to the C/S switch and the C/S injector. The switch will complete the voltage path to ground when cold,... activating the switch/injector only when the key is turned all the way to START.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
86IROC112
Aug 17, 2015 02:00 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
