90 350 camaro into 91 305 Trans Am?
Old Dec 12, 2013 | 04:40 PM
Termanalor117's Avatar
Car: 1991 Pontiac Firebird Trans Am
Engine: 1987 Chevy 355 TPI Mild Cam
Transmission: 5-Speed T-5 WC
I have a 1991 Pontiac Trans Am with a bad 305 (Piston rings) so I think its time to go for a 350.
My question is I found a good 1990 350 from a Camaro and was curious if that would work since its a different model year and "sort of brand". Someone told me the pontiac motors were different form the chevys in the 90's....
I know there is a difference in the ESC Module between 80's and 90's thirdgens, so I'm told but is that a problem for a 91 350 to a 90 305? I guess there was a internally and externally mounted ESC module which was based on the year. Is that a problem for this swap?
Basically I just want to make sure I can do this without any major problems or anything special I have to do other than new chip?
Also my firebird is a manual, does that cause any issues if it came from an automatic?
Old Dec 12, 2013 | 06:11 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 90 350 camaro into 91 305 Trans Am?
Originally Posted by Termanalor117
I know there is a difference in the ESC Module between 80's and 90's thirdgens,. Is that a problem for this swap??
90 -92 are all the same .
Speed density (MAP ) using a '730 ECM ; only the memcal is different to suit the application
You need the memcal ( chip ) out of the 350 computer installed in your computer in place of the 305 one and a 350 knock sensor
Old Dec 12, 2013 | 06:20 PM
Joe Tag's Avatar
Don't forget the pilot bushing. It'd be a beech if he got it all together and left that out.
Old Dec 13, 2013 | 07:40 AM
Ok thanks
Old Dec 13, 2013 | 07:48 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Thanks[/QUOTE]
Here's where you might run into problems.
The 350 might blow your tranny. Lots of info in the drivetrain stickies about that.
The 350 engine computer will not be programmed for a manual so it won't run quite right, but can be reprogrammed.
84z96L31vortec
Aug 20, 2017 12:16 AM
st.evel07
Aug 13, 2015 06:15 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
